13 Apr 2024 05:54 PM
Hi all , sky q not connecting to network , have tried turning on/ off , reboot and update , any ideas
13 Apr 2024 05:56 PM
Hi @Kl88
Hi @Kl88
13 Apr 2024 06:06 PM
Sorted thank you
