Discussion topic: Sky q mini box has been freezing now and again over last couple of weeks. Now after power cut on Sat
This message was authored by gary1999 This message was authored by: gary1999
Saturday night the street had a power cut and now the box turns on, get main menu on screen but when you select a channel it gives you a blue screen. It's connected to main sky q box and has network connection. I've turned it off/unplugged it from wall. Reset on back. Still same problem. What can I do as I suspect its the box with a problem?
Re: Sky q mini box has been freezing now and again over last couple of weeks. Now after power cut on
Hi @gary1999
Reboot the mini as above.
If you still have the issue
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
gary1999
As stated previously I have done all that standard procedures and all I have is a blue screen
gary1999
So with me doing all the obvious stuff do I reishn to myself that the box is faulty and I need a replacement? If so when? I'm paying for multi room but not getting it so obviously I want this rectified soo as possible
