04 Mar 2024 12:53 PM
Sky w box has repeatedly not been connecting
04 Mar 2024 01:05 PM
Hi @QueenPeel1
Assume this is your main Q box.
Connecting to what?
Your TV set or your Broadband and internet?
If it is your Broadband first reset your broadband router.
