24 Apr 2024 12:25 PM
I cannot remove my sky box to replace a new one
24 Apr 2024 12:31 PM
Posted by a Superuser, not a Sky employee. Find out moreSorry @Michelle29 but it's unclear what you're trying to do.
24 Apr 2024 06:58 PM
Sky are sending me a new sky box and I need to return my old one, but I cannot disconnect it.
24 Apr 2024 07:05 PM
Posted by a Superuser, not a Sky employee. Find out moreTake the viewing card out to put in the new box. Perhaps take a photo of the rear of the box showing which cables go where so that you can see where they go on the replacement.
24 Apr 2024 07:19 PM
Two cables I cannot remove. They are ones that are connected to the internet.
24 Apr 2024 07:24 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you can't physically remove them you'll need to get a family member, friend or neighbour to help. The DPD courier wont do it and I'm afraid they won't wait for it to be done once they arrive.
24 Apr 2024 07:30 PM
I have only got my brother that could help, but he is not well at the moment. Can I just return the new box and keep the old one.
24 Apr 2024 07:33 PM
Posted by a Superuser, not a Sky employee. Find out moreYou haven't said why Sky are sending you a new box out? That is usually because your box is faulty. If you refuse delivery of the replacement you'll be stuck with a faulty one.
24 Apr 2024 07:39 PM
My box is fine, but the sales person I spoke to said he would send me a new box. I originally rang to ask for help reducing my bill. The sales person said they can't do that because it's not his department, but for good will he will send me a new box. He did suggest an engineer would install it, but I said just post it because I am out at work all week. At that point I did not realise how difficult it would be to replace it.
24 Apr 2024 07:42 PM
Posted by a Superuser, not a Sky employee. Find out moreI fail to see why Sky would send you a new box unless it was to replace a faulty box or an upgrade.
24 Apr 2024 07:55 PM
I do not know either.
24 Apr 2024 10:04 PM
1tb non 4k to 1tb 4k hdr maybe if recontracted... this is just speculation though until op can give more info.
25 Apr 2024 09:31 AM
@Michelle29You mention 2 cables, is it 2 the same? You mention internet but there is only 1 connection that goes to the router. I think it might be the 2 coax cables that go to the dish. Those do not pull out they unscrew, just give that a check. It is possible they have been screwed on too tight or have cross threaded but just in case you were trying to pull them out.
