16 Jan 2024 05:06 PM
My Sky Q remote was set up on delivery to control the volume on my Onkyo TX-SR605. The AV receiver is connected to the Sky Q box by optical cable.
It stopped working because I made a bad mistake and pressed 7 and 9 which cleared the setting.
Be grateful for any instructions.
Thanks Patrick
16 Jan 2024 07:06 PM - last edited: 16 Jan 2024 07:07 PM
Thanks Patrick
Hi @Patrick0356
Try completly resetting your Bluetooth remote again.
After pairing to your TV you will be asked if you want to pair an Amp for Volume (instead of TV).
On / Off is always reserved for paired TV
17 Jan 2024 01:48 PM
Thanks oldfella! All sorted now
