12 Apr 2024 09:59 PM
Can anyone help please. Our Sky Q box is recording programmes that it thinks we will like even though we have turned off "auto record series from catch-up".
We have also tried highlighting Settings then 0,0,1 suggested in the community chat but we're not seeing "pushed on demand". Putting these number in is doing nothing.
We can't see what else to do. Would appreciate any suggestions please.
Thank you.
12 Apr 2024 10:24 PM - last edited: 12 Apr 2024 10:27 PM
We can't see what else to do. Would appreciate any suggestions please.Thank you.
Hi @AlisonD
I don't believe Sky currently pushes any content to the Q boxes but you can still switch it off
Pushed on Demand is in the hidden menu. You need to press Select after the 0 0 1
Select Pushed On Demand and set it off.
Then next thing to do is to check your Scheduled recordings for any Series links
Make a note of any Programs scheduled that you want to record so you can add them again later. (You could always take a photo instead of noting them).
Once you have made a note or photo'd or the scheduled section complete the following.
Look at the Scheduled recordings and any that have the Green series link arrows go to the right hand side and remove the Series link (leave the Recording scheduled at this time just remove the series link)
When you have just a list of Scheduled Recordings all without series links, cancel each recording until the Scheduled section is completely empty.
Then reboot the Q box .
Once the Box is completely back up and running add back any series links and recordings that you have removed.
See if all the above stops your issues.
12 Apr 2024 11:05 PM
Pushed on Demand is no longer used (and hasn't been for about 4 years now) so it makes no difference. Even when it was used, the programmes wouldn't appear alongside your recordings.
