Discussion topic: Signal issues
This message was authored by niall+fahy This message was authored by: niall+fahy
Signal issues
Hi, we are having signal problems for 3 days, first thought it may be weather related. Have gone through the guide of what to do but no change.
Any thoughts
Re: Signal issues
Any thoughts
Hi @niall+fahy
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
This message was authored by Super_Simmo This message was authored by: Super_Simmo
Re: Signal issues
I'm having the same problem for the last 3 to 4 days.
I'm using Sky Q, no issues with box, or visible issues with sky dish, which I've had replaced a year ago. I've been through the usual Sky trouble-shooting , but I still have an occasional pixelation..
The only thing this 'might' be related to is the recent increase in solar flares, which can temporarily affect satellites and their signals - there's nothing obscurring my dish, nor have I experienced bad weather......I'm at a loss.
This message was authored by Invisiblename This message was authored by: Invisiblename
Re: Signal issues
The dish is not like a terrestrial aerial, it needs to be specifically aligned with the satellite, and there is no way by just 'looking at it' to tell if it has gone out of alignment. You'll need to contact Sky to request an engineer to check & realign it.
I am just another Sky customer!
