Discussion topic: My tv needs software update but my sky remote won’t let me go it
This message was authored by Christine921 This message was authored by: Christine921
My tv needs software update but my sky remote won’t let me do it any ideas please.
The software update keeps coming up every hour we have to keep restarting the tv 📺
This message was authored by Invisiblename This message was authored by: Invisiblename
Re: My tv needs software update but my sky remote won’t let me go it
You need to use your tv's remote
I am just another Sky customer!
Christine921
my tv remote won't work the tv since I've started using the sky remote
hi @Christine921
As it is a software update for your TV I am afraid you do need the TV's own remote - SKY's remote only controls the volume,  power & Input source
Christine921
My tv remote won't work since change over to sky remote
Switching to SKY would not stop your TV's own remote from working.
I am afraid you either need to get it working or see if you can borrow one from someone you may know with a similar TV or buy a new/used one
This message was authored by xenon81 This message was authored by: xenon81
Using the Sky remote doesn't stop the TV's own remote from working. Have you tried different batteries?
@Christine921
As noted above, pairing a Sky remote with a television set does nothing to change the set itself, and cannot prevent the television remote from working.  Whatever is up with the handset, it's coincidental.
Unfortunately a paired Sky remote cannot either action or dismiss a television software update message.
