Discussion topic: My Sky Q box isn’’t connecting to the internet.
This message was authored by CharmaineV40 This message was authored by: CharmaineV40
My sky Q box isn't connecting to the internet and not letting me change the WiFi sever. The main box is fine but despite resets it's not working. Does anyone know how I try and reconnect please. It's been 2 days now!
Re: My Sky Q box isn’’t connecting to the internet.
Hi @CharmaineV40
If it is your Main Q box not connected to the Internet have you tried the following.
To connect a Q mini
Reboot the mini as above.
CharmaineV40
Thanks for this. I've done all of the above and still no joy. It's one of my mini boxes. The main one is fine. Internet is connected and the booster is also running. Do you know if I can do anything from the main box to reconnect? It's not even giving me an option to change the internet server on the mini box 🤷‍♀️
Hi @CharmaineV40
Who is your broadband supplier and where is the Booster (assuming it is a Sky Q booster) located in relation to the main Q box and the mini?
CharmaineV40
Sky is the broadband provider and I have eero internet boosters attached to that. Both are online and working in the rest of the house
OK @CharmaineV40
Afraid the mini boxes will not connect to your Eero WiFi Boosters.
If the minis are using WiFi they will only connect to the Sky router WiFi or the Main Q box WiFi
