27 Sep 2023 05:42 PM
Everytime i try to download something to watch, it takes ages. Whereas before it was ready in a matter of minutes!
Is there something i can do to get the speed up and running normally again
27 Sep 2023 06:11 PM
Hi @Lmh1
28 Sep 2023 06:37 PM
Thanks for the tip, i tried this and followed all steps but it hasnt resolved anything
