Discussion topic: Cannot get sky q box to connect to remote
This message was authored by Tariq007 This message was authored by: Tariq007
Having a problem with the mini box connecting to the remote.
The mini box is on and the green light appears but when in pressing sky on the remote its not working it will not change to sky nothing appears in the tv. The remote is only working when turning the tv on and off.
Re: Cannot get sky q box to connect to remote
Hi @Tariq007
Try completly resetting your Bluetooth remote.
