Discussion topic: Box
This message was authored by Maggiemcqueen This message was authored by: Maggiemcqueen
Box
Hi having problems with sky box connecting to internet.
Keeps dropping out of connection but our other devices are working fine with Wi-Fi
Re: Box
Hi @Maggiemcqueen
Assume this is your main Q box.
Have you carried out a Network reset on the Q box exactly as follows:
Maggiemcqueen
Re: Box
Hi done the reset serval times and it sometimes does come back on but then loses connection again at different times
Re: Box
Hi @Maggiemcqueen
What sort of distance is your Q box from the broadband router?
Also who is your Broadband supplier
This message was authored by kpraff This message was authored by: kpraff
Re: Box
i am having exactly the same problem. Also the mini box cannot to the main Q box because it keeps dropping of our network. So everything stops working when i move away from Sky Broadband as a provider 🤔
Re: Box
hi @Maggiemcqueen @oldfella i am having exactly the same problem. Also the mini box cannot to the main Q box because it keeps dropping of our network. So everything stops working when i move away from Sky Broadband as a provider
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Box
@kpraff wrote:
hi @Maggiemcqueen @oldfella  So everything stops working when i move away from Sky Broadband as a provider
No, but perhaps your new provider's WiFi is interfering with the Q's own private mesh (5GHz Channel 36 / 80MHz).  Try changing the 5GHz channel.
Also, for non-Sky ISP the main connection will only use 2.4GHz.  You may wish to have a separate SSID for that (that doesn't forward to 5GHz as that will drop).
I am just another Sky customer and my views are my own
