Discussion topic: Sky go connection
This message was authored by Jac11 This message was authored by: Jac11
Sky go connection
when I try to watch sky go on my iPad in London I get a pop up message on the screen saying I cannot connect in this country If I use my sky go app anywhere in the Uk there is no problem and I can watch it fine Can anyone help
Re: Sky go connection
Are you using anything like a VPN via it, if so try disabling it.
Jac11
Hi Not using a VPN just using the sky go app
What WiFi signal are you connecting to there?
If it's not your own broadband then you won't have any control over where it apears to be.
On average, new discussions are replied to by our users within 3.6 hours
