Discussion topic: 99% of the time I turn on my sky puck I have to reset it to make it work. Works fine after a reset-
This message was authored by Adrian67 This message was authored by: Adrian67
My puck only works after a reset (power off then on again)
is this a puck problem?
This message was authored by mikealanr This message was authored by: mikealanr
Re: 99% of the time I turn on my sky puck I have to reset it to make it work. Works fine after a res
Hi @Adrian67
So.when you press the button on the remote, it's not responding? What happens if you press the button underneath the puck?
It might be worth un-pairing and re-pairing your remote if it's working using the button underneath. See: https://www.sky.com/help/articles/remote-control-help-sky-glass
The other thing to try is turn Networked Standby Mode ON and overnight power saving OFF in the startup and standby section of the settings.
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
