Discussion topic: Wrong sky Internet option
This message was authored by Lidija This message was authored by: Lidija
Hey I think I ordered wrong sky Internet option. I want to have just Internet access in my new rented home. I received a message that some IT worker will come to drill wall? How can I discuss this and change just to normal home Internet access?
Re: Wrong sky Internet option
@Lidija
Could you enter you new full address below and post the table and notes after removing your address from the image
@Lidija
I reckon whatever speed you have opted for is going to be by full fibre fttp.
Isps are increasingly providing previous superfast fttc speeds via fttp
In a 'fibre priority exchange area' there typically won't be an option for an ISP to order service over existing copper: the assumption is that all new provision will involve the deployment of FTTP, which does almost inevitably require drilling to get the new optical cable inside the property (plus wall mounting an ONT)
@Lidija
Normal home internet is now FTTP and if FTTP isnt yet in your home a new install will be scheduled with a cable drilled through the wall.
I am NOT a Sky Employee
