23 Jan 2024 11:39 AM
I have had a new 203 router supplied - so - it connected fine and had good wifi on my PC but I needed to connect my home security system which requires 2.4 = I followed instructions on this forum and logged into router and unsynchronised the 2.4 and 5 ghz then renamed the 2.4 channel and suddenly the whole wifi dropped (and phone line) and now I cannot connect at all. The troubleshooter says there is a problem with the cable between the purple ports - despite disconnecting etc it cannot fix it. Have tried reset and cannot log into the router anymore as it is not connected.
23 Jan 2024 11:56 AM
Posted by a Superuser, not a Sky employee. Find out more@Jcholmes If you are trying to reset the router you need to hold the reset button for around 20 seconds. When trying to split the Wi-Fi frequencies this is best done over a wired connection.
23 Jan 2024 12:02 PM
Thank you - I tried that and it is still erroring on the cable between router and wall.
Am I right in thinking it is possible to separate 2.4 and 5 ghz on this model?
23 Jan 2024 12:03 PM
Posted by a Superuser, not a Sky employee. Find out more@Jcholmes Which model of router do you have from the link below
23 Jan 2024 12:07 PM
Posted by a Superuser, not a Sky employee. Find out more@Jcholmes you can definitely separate the bands on the black SR203 hub but couple of gotchas first is using any device running ios can cause issues with logging on and saving settings. Ideally use a non-Apple device if you can't use Chrome rather thsn Safari.
If you use a device connected by wifi when you apply the chsnges you will be disconnected as the hub applies the changes. Depending on the changecto SSIDs you mske your device msy require to be reconnected oncectge hub restarts. Hencecthe advice to useca device connected by ethernet.
23 Jan 2024 12:14 PM
sky router model SR203
