18 Jan 2024 05:00 PM
Hi I've just upgraded my broadband to the fastest speed. I've received a new Ethernet cable through the post but not a new router people I know have new boxes with lots more lights on and I wondered if it's brought with the engineer or if it should be delivered beforehand?
18 Jan 2024 05:25 PM - last edited: 18 Jan 2024 05:26 PM
@Kymm what router do you have ?
see link below out of the 4 pictured which do you have
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
18 Jan 2024 05:48 PM
Posted by a Superuser, not a Sky employee. Find out moreThe standard router for Ultrafast is the SR203 which is the black one that stands upright.
You'll only get the newer white Sky Max router if you've added Sky Max to your order.
18 Jan 2024 06:39 PM - last edited: 18 Jan 2024 06:41 PM
The ethernet cable is the 'conversion kit' which permits the connection of the WAN ethernet port on a Sky Broadband Hub to an ethernet port on an ONT (Optical Network Terminal, aka 'fibre modem')
Other ISPs may ship routers with 'lots more lights' but a Sky Hub in use with FTTP has four. There are some more on the ONT if that helps: this is fitted as part of the optical cable installation and not sent in advance.
18 Jan 2024 11:35 PM
Hi everyone I have the sky hub which stands upright but only has 3 lights
23 Jan 2024 10:04 AM
Posted by a Superuser, not a Sky employee. Find out moreIt should have 4.
Power, Internet, WiFi & Voice
