Discussion topic: Unable to log into Sky Broadband Hub
This message was authored by LionHeart6790 This message was authored by: LionHeart6790
For some reason, the SSID (LIMELIGHT) has completely disappeared and reverted back to the standard SSID on the box.  I tried to log in using the admin password, I had and it wouldnt work.
I then decided to factory reset the unit to try and get it back to normal.  I went to 192.168.0.1 and tried
admin / sky - not working
admin / password on back of hub - not working
admin / lightweight - not working
Ive tried resetting the hub with 10 seconds and 20 seconds, see the power light flash.
Its driving me up all the wall, can someone help please?
Re: Unable to log into Sky Broadband Hub
@LionHeart6790  Have you tried admin | Wi-Fi password to see if it let's you get into the router settings.
LionHeart6790
Spoke with advisor who suggested holding reset for 60 seconds which did a hard reset on hub.  This fixed the issued
This message was authored by johng2 This message was authored by: johng2
I also have the same problem every post tells me it is admin and my wifi password. It is not.
