Discussion topic: Still having issues with broadband
This message was authored by Robbo0410 This message was authored by: Robbo0410
Hi I'm still having issues with my broadband, I've rang Sky and they have escalated it to Openreach who say there is no problems, router is resetting itself at least 2-3 times a day I've had a new router delivered today and within half an hour of connecting and powering it up it has done the same thing, I've had around 4-5 replacement routers and still haven't fixed the issue this has been ongoing for months, would a kind moderator be able to raise a chat for me with an advisor on here as it would appear ringing Sky is a complete waste of time they just suggest sending a new router out, I need an actual broadband engineer to come out to my home and see if there's any issues cause apparently there are none on Sky's end as well as Openreach's, I have a TV engineer coming out on Thursday I've been advised to speak to them about the broadband problem....
Re: Still having issues with broadband
@Robbo0410
If the router is resetting itself I am not sure what an engineer is going to be able to do.
Can you please post your router stats
I am NOT a Sky Employee
Robbo0410
@jamesn123
@Robbo0410
So 1hr15mins ago the router rebooted. Did it do that itself?
Robbo0410
@jamesn123 yeah I've had the problem for a while now, it just randomly does it, could be on for a full day could be for a few hours before it resets itself, it doesn't do it a set time it's just random times, got a TV engineer coming out on Thursday cause Sky think it's the main box and mini box causing an issue, no issue would cause the router to reset itself, had a phonecall from a broadband engineer earlier today he said it's worth asking the TV engineer to run some tests and see if they can find anything as they'll more then likely know a thing or two about broadband
