Discussion topic: Slower speed from router
This message was authored by Stuart771 This message was authored by: Stuart771
Only getting between 100 - 150 mbps
This message was authored by JimM1 This message was authored by: JimM1
Re: Slower speed from router
@Stuart771 More information is required from your brief description. Is this a new installation, which type of Speed/Broadband package do you have, Are you connected over Ethernet cable or is this a wifi wireless connection, what are you speed testing on, and have you run the service checker from your sky account to test your connection?
This message was authored by Cosyloft This message was authored by: Cosyloft
Slower to 58 since bt worked on
was over 70
