22 Mar 2024 05:38 PM
Seem to be getting speeds well below expected for giga fast. Bot sure if its the main router.
stats are below
Is this ok
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 3828072 8603517 0 3792789 162330576 00:11:42 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 5215 0 0 23738 0 00:11:47 WLAN (5 GHz) Up 8051425 3795521 0 0 3856672 00:11:46
26 Mar 2024 11:35 AM
Posted by a Superuser, not a Sky employee. Find out moreThat would be because your testing the speeds over WiFi.
You are not going to get near gigafast speeds over WiFi you need to use ethernet.
