34
Discussion topic: Sky broadband WiFi signal keeps dropping out
This message was authored by Lavender45 This message was authored by: Lavender45
Re: Sky broadband WiFi signal keeps dropping out
Our Sky broadband is dropping out two or three times per day.  My son has managed to capture 16 screen grabs which show no internet connection.  It is very annoying, as I work from home and have to reconnect all drives which is time-consuming.
Please can you provide an explanation how to get those router details.
And then what ?
This message was authored by Matthew This message was authored by: Matthew
i have just joined back to sky today after previously leaving them due to poor broadband connection, and low and be hold day one of the internet and it drops out every couple of hours. Never had any issues before with my previous supplier how do i get this resolved.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Matthew
Can you run the Broadband Test from the MySky App or using this link:
https://www.sky.com/pages/sky-com/test-your-broadband
My you please post your router stats, this can be done following the information in the link below.
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014
"Sometimes, the only choices you have are bad ones, but you still have to choose"
please see attached Stats for my current internet.
System Up Time: 08:19:44
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 29551 68857 0 8421 13845 00:05:52 LAN Up 14170731 16890129 1 912202 13021791 08:19:44 WLAN (2.4 GHz) Up 1052685 274847 0 36576 1831 08:18:16 WLAN (5 GHz) Up 27359931 11284171 0 0 221510 08:05:49
Broadband Link Downstream Upstream Connection Speed 79994 kbps 20000 kbps Line Attenuation D1(4.2 dB) , D2(10.6 dB) , D3(17.7 dB) U0(1.6 dB) , U1(7.9 dB) , U2(13.1 dB) Noise Margin 6.4 dB 12.1 dB
This message was authored by Ian+Dunn This message was authored by: Ian+Dunn
Over the last two weeks the Wi-Fi signal keeps dropping out. The light is orange. Sometimes it reboots and other time I have to switch it off and back on.  Very annoying.
@Ian+Dunn
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
This message was authored by fiona.mac This message was authored by: fiona.mac
Hi. My home wifi keeps dropping every 30mins or so, which is impacting my working from home. Could someone please help, guide me. I've done the on-line tests but they only work when there is a connection. Below are my stats in the hope this helps. This issue has been going on for over a week now. Thanks.
@fiona.mac
Your stats are not of any use right now as you only rebooted the router 13mins ago unless that wasnt you?
Can you post your router stats next time you notice the issue occuring, without rebooting the router
I am NOT a Sky Employee
@jamesn123 thanks. I didn't restart the router; the connection keeps crashing and sometimes the router power button goes red (no other lights), but mostly it is the internet light which starts flashing / goes to amber / goes off / then restarts. New stats below
@fiona.mac
Your downstream speed and noise margin appear to be varying substantially through the day every time it happens the noise margin increases to stabilise the line at the expense of your speed. Whilst sky essentials doesn't have a guarantee i believe if the line drops 10 or more times a day you may still be able to call sky due to instability
Call sky on 150 from your landline or
zero three three three seven five nine one zero one eight from any other phone
Or if in Ireland
Call sky ireland on
08.185.00.27.2
Remove all the full stops
Thanks @cookiemonsteruk (from one BSAC diver to another 😊). Am talking to Sky now
@fiona.mac
Let us know what happens
@cookiemonsteruk Turns out that I'm on ADSL and the quality of the line is poor. I've upgraded to Sky Broadband Superfast for £1 extra for the next 18 months
@fiona.mac
That was going to be my next question have you been told what speed you'll get
If you wish enter your full postal address below and post the full table after removing your address from the image
@fiona.mac
That is not a solution, your router is clearly rebooting itself and the line is dropping. This issue will likely be made worse by being on a fibre connection unless you are getting FTTP. Sorry to say but the agent has fobbed you off.
