04 Sep 2023 11:01 PM
Hi all - Grateful for any help. I recently switched to Sky Max Hub from EE. To improve Wi-Fi in our house, and to provide Wi-Fi to a garden office, we have been using TP-Link power line adaptors. Since switching to Sky, I no longer have Wi-Fi in the garden office. I've even tried an Ethernet connection to the TP-link, but that wasn't recognised by my computer. I have no idea what to do now - I've tried re-pairing, etc. I've heard Sky and TP link aren't always compatible. Has anyone had this problem and fixed it?? All help is very welcome (and please note, I have very much not tech savvy!) Thanks in advance!
05 Sep 2023 06:07 AM
Posted by a Superuser, not a Sky employee. Find out more@MS31 I doubt there is a fundamental problem between the new SR213 Sky hub that Wifi Max uses and your powerline adapters if you are connecting from the ethernet ports on the hub to a PC. I had Wifi Max myself and succesfully used Devolo powerline adapters to an iMac as the wifi connection was too slow. So I would unplug the adapters and reconnect them and run their set up again.
However I think you may hit issues if you try to hang one of Sky's "pod" extenders off a powerline link. Sky are still making changes to the Wifi Max set up to improve performance. One of the advantages of the package is you should be able to get a visit from an engineer but becaware thst officially Sky never support powerline adapters.
05 Sep 2023 08:01 AM
Thanks! It says there's Wi-Fi, but it's only 1bar, which is odd given I had full signal when we were on EE. I've unplugged, replugged, paired and repaired and it's not changed.
I tried using an Ethernet cable, but it still seems to be assigned to our old router. I read somewhere that resetting it should help, so fingers crossed that works today!
05 Sep 2023 08:02 AM
I should add - ours is a v simple set up. One sky max router, one puck for the tv, everthing else on Wi-Fi and no other problems in the house. It's just getting wifi to the shed...
05 Sep 2023 08:30 AM
Well, I managed to reset the TP-Link, and can now get internet thru an Ethernet cable (yay!!). The wifi still only shows the little dot / one bar. Annoying that the wifi element doesn't seem to actually work - does anyone know if there's a fix?
21 Jan 2024 04:39 PM
I have just upgraded to a Sky Max Router from Sky Broadband SuperFast. Previously had a TP-Link extender working successfully to Wi-Fi connect with Ring Security Camera outside. I now find it impossible to reconnect using the Sky Max Router. I have attempted through Ethernet cable, WPS and TP-LINK website configuration. The RE light flashes on the extender but never reaches solid status.
Help please.
25 Jan 2024 08:25 PM
Further to this I called Sky Helpline and they posted me a new POD that very simply and powerfully extended the broadband range. After a few remote tests they suggested the new Sky broadband router was incompatible with my dated TP-Link extender.
