Discussion topic: Sky Hub keeps resetting
This message was authored by Harsh13990 This message was authored by: Harsh13990
Re: Sky Hub keeps resetting
Hi,
Can someone tell me how this got resolved?
I am facing the same problem as well.
TIA,
Harsh
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
@Harsh13990 wrote:
Hi,
TIA,
Harsh
Highly likely to be a faulty router, call Sky and they will check for you.
Passing on the tips I have learned in over 23 years as a more than satisfied Sky customer.
This message was authored by FlokiBear This message was authored by: FlokiBear
I'm having exactly the same problem. The Internet drops multiple times a day and Zoom meetings are a disaster at the moment. Can't play the radio through the Internet as it keeps cutting out. Web pages load slowly and I keep getting the message 'unstable internet connection' even though all the standard checks say everything is fine. Sometimes the box re-boots itself - this happened right in the middle of a Zoom meeting - embarassing.
FlokiBear
This message was authored by skydave3 This message was authored by: skydave3
Mine has been doing this for a while now, but not all the time. I can go months just fine and then a couple of weeks where it will restart at the same time everyday. This last week it's restarting at 10pm every night.
I've tried all the restarting etc but it just seems to have a mind of it's own. Never found an answer and the router runs perfectly fine otherwise.
This message was authored by Rose64 This message was authored by: Rose64
Hub should have 3 green lights but several times a day one light goes off and then flashing amber comes on and we keep disconnecting and then connecting
Yeah that's what happens to me when it's going through these resetting phase.
This message was authored by Alex471 This message was authored by: Alex471
I have the same issue. Keeps disconnecting and powering up again. Sky customer service suggested it was a power issue, have tried however connecting it to various sockets around the house and the issue persists. Forgot to mention that I had sky deliver to me a new hub and the same thing happens with the new hub after being initially fine for a good 6-7 hours. Now booked an engineer appointment.
Yeah I don't think it's anything in our side. I've not had the issue for a good couple of months now, but it'll random come back for a week or two at some point then go again. I've just accepted it will happen sometimes randomly.
This message was authored by Ol+boy+john This message was authored by: Ol+boy+john
Re: Sky Hub has changed its address.
My new router has assumed the identity of the previous router. How could this happen old router is not plugged in to a power source.?
@Ol+boy+john
Do you have Sky Q or any boosters?
I am NOT a Sky Employee
Sky Q installed last 2 months
@Ol+boy+john
So your router would have pulled the name from the Q box which I assume was connected to your old router at some point
Yes that could be so.
Have turned off new router ,rebooted no change back
