17 Jul 2022 11:09 PM
I need to restart my router whilst away from home.
Is this even possible?
If I contact Sky Technicall, can they restart it for me?
18 Jul 2022 08:03 AM
The only way would be inadvisable due to security issues
Log onto you hub
Go to advanced settings and sign in
Go to remote managenent and take a note of your public ip address and port number (usually 8080) and enable remote management.
30 Nov 2023 01:51 AM
192.168.0.1
Pop that into your mobile browser search bar.. then use admin and sky to get into what you need
30 Nov 2023 08:22 AM - last edited: 30 Nov 2023 08:22 AM
Posted by a Superuser, not a Sky employee. Find out more@BronwynBrown that address only works from devices connected to your home network it wont work when you are not on your home network.
