Discussion topic: Reconnection after house renovation
This message was authored by Char2309 This message was authored by: Char2309
I have been a sky customer for 14 years.
However, recently I have completed some house renovations. As a result;
1. I need the telephone socket to be reinstalled / connected to outside
2. the builders had completely removed the external wire to the Sky dish (which is still on my roof).
I am aware I will need an enginger (s) to help reinstall (Openreach engineer and Sky engineer??) but I am struggling to get this help on the Sky website from using the automated options.
Please can anyone help?
Thanks.
Charlene
Re: Reconnection after house renovation
@Char2309  You will need to call Sky.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Char2309
Ok thanks. I did try calling Sky previously, however I waited for an hour before giving up.
I will try again at another time, as you have suggested.
Thanks for your help.
@Char2309
Note that Sky will almost certainly (and quite reasonably) charge for both reconnections.
Char2309
I am expecting to pay, that is not the issue. The issue is trying to find a way to actually get through to someone at Sky that can assist me. Thanks.
@Char2309
The easiest way will be to call Sky and get yourself in your broadband fault queue. Then when you get through to an advisor just tell them you've had construction work done and your telephone cable has been damaged/removed so you'll need someone to come out and fix it.
I am NOT a Sky Employee
Char2309
Many thanks
This message was authored by PhilipC12 This message was authored by: PhilipC12
Im having the same problem here, and the girl on the phone just keeps asking me to check if there are lights on the modem! 😄 Its hillarious, and infuriating.
