Discussion topic: No broadband connection but test shows all fine
This message was authored by Scraffa This message was authored by: Scraffa
I have expedienced no internet connection over a number of hours over the past 2 nights, early morning actually at around 2 and 3 am.
I have checked the signal and run various test from the Sky Broadband part of the my sky app which has indicated good signal and no problems. Frankly this is **bleep**. I have a number of screenshots to support my view.
Any similar issues? Having watched Mr Bates v PO, this is no way near the seriousness of that fiasco, but sky does appear to me to be following a similar strategy.
This message was authored by daveNOS This message was authored by: daveNOS
Re: No broadband connection but test shows all fine
@Scraffa It is in no way similar to what happened and continues to happen with the horizon scandle, mentioning it in the same breath is insulting to those involved,and frankly a massive overreaction on your part.
Loss of connection during the times you mention is usually down to essential maintenance, it's unavoidable and Sky can't do anything about it(happens to all ISP's that use the Openreach network).
-------- Please note i am not a Sky employee ----------
Scraffa
In no way did I want compare with Horizon, on very loosely in terms of company strategy.
I fully understand downtime but I question why am I told the connection, speed and transfer speed all good and that there are no problems? I hope this isn't another social media approach where others negatively comment but don't respond to the issues.
If you have Q television, it's typically the box(es) going into a power saving mode and so dropping the WiFi mesh which does that.
Alternatively, there may be Openreach network maintenance happening locally, which will be timed to occur when fewest people are online.
Scraffa
Many thanks for the response.
