Discussion topic: No Internet connection error cod MR04
This message was authored by Closethegap This message was authored by: Closethegap
My wifi connection keeps dropping out with Sky. When I run a status check through sky.com it states everything is fine with the line and area. I have restarted the router several times and the connection comes back but after a couple of hours the issue happens again. We are finding this is happening a lot, and we have wifi controlled radiators, and these keep turning off!
Re: No Internet connection error cod MR04
@Closethegap
Is that mr104 ? Do you have sky q tv?
Closethegap
Yes. In setting internect connection is showing 'x' plugged out, press reset, does not help. Blue screen 'no jnternet connection'
This message was authored by Martin_r This message was authored by: Martin_r
Yes I'm having the same issue! Have rang sky numerous times and there useless! Apparently can't send and engineer out as I had one out last week and it still is on the system so can't have one until that appointment is cleared even though it's been and gone! Usless!
