Discussion topic: My sky router has 4 lights but only first 3 light up can anyone advise me
This message was authored by Hooefull This message was authored by: Hooefull
The fourth light on sky router wont light up
Re: My sky router has 4 lights but only first 3 light up can anyone advise me
@Hooefull
Is that the voice light?
Where does the phone normally plug into . The mastersocket or the back of the hub?
@Hooefull
If your exchange area isn't currently provisioning SOGEA broadband then it won't.
Are you trying to get voice telephony working?  Did you previously use a telephone handset plugged into a wall socket?
This message was authored by Lozzie01 This message was authored by: Lozzie01
sky router has 4 light but on first 3 are on
This message was authored by JimM1 This message was authored by: JimM1
@Lozzie01
The 4th LED is used to indicate the VOIP function and only if you are signed up for this with SKY.
If this is a new installation it will take up to 24hrs before it can be active. If you are signed up for this then your landline phone will need to be connected to the rear of the router in the telephone connection.
If not using then the landline phone is connected as normal to the telephone point of your master socket.
@Lozzie01
Also the link to sky explaining if you want to check.
What you need to know about Internet Calls | Sky Help | Sky.com
