30 Mar 2022 07:12 PM
After cancelling the Sky Q account my internet has been rather poor.
The booster we have now only shows a power light.
I have tried to reset the booster but unfortunately it does nothing.
I have attempted to press the pairing button for a few seconds but no light flashes.
The main router is still working but unless you sit right next to it... there's hardly a reason to try get online through it.
The booster is in the same room.
31 Mar 2022 10:37 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @Sam1975
If you got rid of Sky Q its possible your Q box or mini boxes were providing a stronger signal which has now dissapeared.
If you are unable to get the booster to reconnect then you may need to try connecting it via ethernet.
22 May 2022 04:22 PM
Also having the same problem with my sky booster, not sure of the cause but it randomly stopped working about a week ago. Only green power light, reset not working and the amber connection button to connect to main hub not even flashing. Now can't get the internet connection on our tv as that's the room we needed a booster. Can't move the main hub as only one master socket in the far bedroom. Always worked fine before.
01 Jul 2022 09:04 AM
Exactly the same issue, booster just stopped working with the power light green and nothing else showing. It worked a week ago....
01 Feb 2024 10:04 PM
I'm having the same issue.
Only a power light. Resetting does nothing. Unplugging does nothing. WPS button does nothing.
Any ideas?
02 Feb 2024 08:31 AM
Posted by a Superuser, not a Sky employee. Find out more@Davidgbee assuming the hub does not connect when moved close to the hub it is faulty and needs replacing if Sky provided it give them a call.. If ithe unit does spring back into life then move it roughly half way between where the hub is and where you need to boost as Boosters need a decent signal to work.
02 Feb 2024 08:38 AM
Thanks @Chrisee
I can't get it to do anything when resetting or recovering other than change the power light from green to red. The WPS button does nothing so I can't trigger it to re-search.
I'll give Sky a call
Thanks again
