08 Jan 2024 06:55 PM
Hi Just upgraded my sky broadband to include sky glass. Took delivery of the TV and hub today, TV appears great. Changed the SSID on the new hub to the old name and password to make it easy and not have to change 20/30 devices for their connections. However I have a couple of devices on 2.4GHZ and only operate on that frequency. However the next MAX hub does not let you rename the 2.4, only rename both SSIDs which is not what I want. The rename worked for most items but my SMART outdoor lights will not work as they only work on the 2.4GHZ, How can you rename the 2.4GHZ name?
09 Jan 2024 11:16 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @Hairy_Gav
You'd need to split your WiFi bands on the max hub
09 Jan 2024 11:22 AM
The procedure is to disable the 5Ghz wireless band, connect the devices that will only work on 2.4Ghz, and reenable the 5Ghz wireless band.
09 Jan 2024 07:02 PM
Thanks have tried that, but the 2.4switch would not operate after doing that. Thanks though. I have now reverted to just broadcasting the 2.4 and disabled the 5. A few passwords later and back up and running on all. Frustrating though that I am not able to do so like the old sky router. Hopefully I won't need the 5 or later wifi enabled devices that I get only work on 5!
09 Jan 2024 07:03 PM
Thanks. That's what I was trying to do and it would not allow me to split like the old sky router which was 3yrs old. Reverted to just broadcasting the 2.4 just now....hope I don't need the 5 in future!
09 Jan 2024 07:31 PM
@Hairy_Gav wrote:
. it would not allow me to split like the old sky router which was 3yrs old.
The Max Hub is fundamentally different to previous Sky router hardware, and based on technology from Plume.
09 Jan 2024 07:38 PM
Yeah see that. But shame that they don't tell you before hand. Loads will have these type of switches that control electrics in the house that can only work on 2.4. Other providers allow you to broadcast 2 frequencies with different SSIDs......just no Sky eh?
09 Jan 2024 09:21 PM - last edited: 09 Jan 2024 09:23 PM
Typically the problem is that the initial setup of such things cannot procede when the IoT hardware is using 2.4Ghz only but the app controller host device is on 5Ghz. Plume actually has a dedicated solution for that, which unfortunately isn't available in the My Sky app.
10 Jan 2024 07:27 AM
Posted by a Superuser, not a Sky employee. Find out more@Hairy_Gav can you post details of the smart plugs which would not stay connected when you switched the 5GHz band back on as other users have reported their kit still worked.
Running the White Wifi Max hub with only the 2.4GHz band is like buying a fast car and never changing out of first gear. The hub offers fast wifi which requires both bands to give the high speeds you are paying for.
10 Jan 2024 09:25 AM
Agreed re the 1st gear.... but with max download of 25mb I won't notice eh. It's electrical switches I have that controls outside lights. I checked with my spark ⚡️ pal and he said these type don't come in 5ghz frequency. Hence turning the 5 off eh.
