Discussion topic: Low security
This message was authored by chunk44 This message was authored by: chunk44
Low security
I think my wife security is weak because my iPhone has highlighted this issue what is the fix for this
Re: Low security
@chunk44
Iphone bought in wpa3 before it was available on domestic routers, the only sky router that does it is the sky max hub however you should be able to change the settings on the iphone to wpa2 or wpa transitional
