Discussion topic: Limiting WiFi usage for teens?
This message was authored by KezJJ This message was authored by: KezJJ
Is there a way to temporarily block WiFi access to a particular device or devices?  Seems this may be the only discipline method left for problem teens.
Re: Limiting WiFi usage for teens?
@KezJJ
Parental Controls are built into the white Sky Max Hub, available to Sky Broadband subscribers who add the 'WiFi Max' supplement at an additional monthly cost.
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
Older black Sky Q and Sky Broadband Hubs no longer have access to Broadband Buddy, the previous control app which used to be a component of the 'Broadband Boost' add-on.
KezJJ
I have the older black Sky Q router, but when I go to the My Sky account, there are no upgrade options available to me and no mention of WiFi Max.
@KezJJ if you have Sky Q TV boxes the new hub isn't compatable so doesn't appear as an option.
KezJJ
That's not very good then.  So I can't actually follow through with my threats to restrict their WiFi access, because my sky box's are a couple of years old. 😞
 I don't think I have the option to upgrade to anything else in my area as it's too rural.
