Discussion topic: I got delivered a hub after a engineer installed mine
This message was authored by Shazia4 This message was authored by: Shazia4
My engineer came and my router had not arrived so he got one from his van but I have just received a hub in the post what do I do
Re: I got delivered a hub after a engineer installed mine
@Shazia4
Are they the same hub?
@Shazia4
I would keep it for now and if Sky email you to say it needs to be returned then that is what you will need to do but the chances are they probably will not do,
