Discussion topic: Hi. How do I change my WiFi name
This message was authored by Klaudiak This message was authored by: Klaudiak
How do I change my WiFi network name?
Re: Hi. How do I change my WiFi name
@Klaudiak you can edit both the SSID and wifi password using these instructions https://www.sky.com/help/articles/find-and-change-your-wireless-password
Klaudiak
Hi! When I log in, it allows me to edit, but as soon as I press apply, a blank screen comes up with "lost connection"
@Klaudiak if you are using a wifi device that is exactly what should happen as you have changed the wifi id you device is using to connect. Using an ethernet device if you can but if you have to use a wifi device avoid Apple devices if you have no choice use Chrome not Safari but it may take a couple of attempts to get the new setting to stick.
