04 Dec 2023 09:49 PM
Main PC is Windows 11 pro i5 64 bit, 32 gig ram less than 12 month old...
i am next to the hub ER115, 2m cat 6 cable... all works fine.
i try to access it via 192.168.0.1 but just a black screen with 'transfering data' in bottom left corner.
it just just sits there... no hub settings appear at all.. no sign in etc..
tried 3 browsers with adblock turned off etc... is it a Win 11 issue ?
But if i use a laptop wired or wireless it connects immediatley to hub, no issues...
so i do have access to my hub, but why not with my main PC... ? .. I have done reset router etc..
05 Dec 2023 12:29 PM
Posted by a Superuser, not a Sky employee. Find out moreI've never seen the transferring data wording when accessing a Sky hub. Can you please send a screenshot of what you are seeing?
