Discussion topic: Broadband not working
Robbi
This message was authored by Robbi This message was authored by: Robbi
Re: Broadband not working
Have brough a micro filter and have plugged the broadband end into the 'modem' part and the purple end into the purple broadband connection on the hub, and still no luck.
@Robbi
Are you a new sky customer or did they send out the hub to replace an older hub?
When is your activation date?
***EDIT ***Apologies you already answered those questions
It could be a failed activation in which case you would need to call sky
This message was authored by JimM1 This message was authored by: JimM1
@Robbi A lot depends on the specific wiring of the master socket, and the type you have would normally be for connecting a phone to the telephone line. The micro filter is required to connect the router to and seperate it from the telphone side.
See the link i sent, and it will show you a picture on the guide....
Plus hope you are not leaving the router on the Radiator, they do not like getting hot.
