Discussion topic: Broadband down
This message was authored by Den16 This message was authored by: Den16
Broadband down
Hi , this is the 3rd weekend in a row that I'm having problems with my broadband. What seems to be the actual problem?
im fed up with this , it had cost me money to buy new data
This message was authored by Icewolf83 This message was authored by: Icewolf83
Re: Broadband down
Im having the same problems the past few days. Before they raise the prices i think they need to fix all the issues or they'll be losing customers as it also affects the sky streams
Re: Broadband down
@Icewolf83 & @Den16 it is inevitable that as there are over 6 million Sky broadband customers some will have issues at any one time. Most issues fall into 2 groups the first is line issues which with copper phone lines shich can be decades old do fail. The second are issues within customer's home networks which can be caused by dodgy Sky hb's but more frequently can be down to wifi issues.
To determine what is the problem for each of you cgeck the LEDs on the hub when you lose connection, if the internet lightis amber there is an issue with your line. In thst case run the connection test in the My Sky app overca mobile connection as that will tell you if there is a known fault affecting your line if there isnt call Sky so they can getvan engineer to come out and check your line.
If the internet light is green the issue is likely to becwithin your home so if restarting the hub doesn't help post some more details woth your hub's stats see Find your Sky Broadband router statistics
Den16
Re: Broadband down
I had a new router and they have changed my in house line box but I still have all these problems, I'm fed up calling and waiting and hour+ for answers . I think I'm just going to cancel sky it's been a nightmare for a month .
They have a cheek to offer me £9.33 for inconvenience when I had to purchase more data which cost me £24
They are a joke
