Discussion topic: Broadband constantly going off
This message was authored by Gill591 This message was authored by: Gill591
Really feel like cancelling sky broadband and going with someone else as my broadband goes down at least 3 times a day.
Re: Broadband constantly going off
@Gill591 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by Geoff71Grace This message was authored by: Geoff71Grace
Mine has too. Dropping internet (not Wi-Fi) several times today. A power down and power back up fixes it but this has happened about 6 times today. Not a sustainable service if we keep having to do this.
@Geoff71Grace  Can you try running the the broadband test, a link to this can be found in post 2 of this thread.
The test shows nothing up as when you run it broadband is back and 4 green lights are on. But that doesn't change the fact that the modem / router lost connection of its own accord six times today. There's something else wrong in the whole set up that the broadband checker isn't designed to detect.
Gill591
Same here you do the test they tell you to unplug everything start plugging everything in one by one test again  sometimes it comes back sometimes it doesn't. Takes 15 minutes 3 to 4 times a day, not good practice not good service.
