16 May 2022 10:28 PM
Hi all
i am trying to get an xd6 based mesh setup to replace the sky hub.
can I use the same settings as have been posted here previously for the xt8?
17 May 2022 08:11 AM
The setting used by the XT8 would be either the same or very similar to DHCP Option 61 under the WAN tab and DHCPv6 Prefix Delegation (PD) under the IPv6 tab the authentication string is the same.
18 May 2022 08:13 AM
Thanks. So with the help of all the useful posts here I have one of the xd6 units up and running as a router.
This is probably a really dumb question but how do I go about setting up the second unit in the mesh. Do I need to change the settings on the second one in the same way or does it inherit them from the first?
18 May 2022 08:15 AM
When setting up the second unit in a mesh then the WAN should operate in mesh mode which is one of the options.
21 Jan 2024 09:05 PM
@Emperorshand Have you had a good experience with the XD6? Was looking at that or XT8 to replace sky hub but doing wired backhaul so don't think I need the tri-band. Cheers!
31 Jan 2024 07:21 AM
Hey. It has worked great for me. One node down where the crappy sky router used to be and one up on the first floor landing. We have no missing coverage anywhere across the three floors now.
22 Mar 2024 09:16 PM
Hey all - will the XD5 work also?
asus d.o.t com/uk/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-xd5/
23 Mar 2024 03:25 PM
managed to get through this and do it myself based oh previous instructions.. all works on this device too. only question. i have this message on the status, however any idea? showing really good speeds thought, better than my standard sky router
23 Mar 2024 03:32 PM
Its something to do with ddns settings. Would advise get the device registered with asus and submit a ticket
