The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
28 Apr 2021 02:40 PM
Hi,
I’ve got this problem with my new Sky Ultrafast service and have had since I had it installed 5 long, long weeks ago…
In short the Sky router, every 2-4 hours, resets itself -the ethernet, Wifi and phone lights go from green to not lit at all and the power light goes red. It then restarts itself one light at a time. As I said this has been happening every 2 – 4 hours since I had the service installed.
So essentially, I have an intermittent broadband service and a basically unusable phone service (phone calls drop out due the reset etc).
As you can imagine I’ve been on to Sky about this quite a bit. I will say that every sky person I’ve dealt with has been kind, patient and sympathetic and keen to help me resolve the problem. Unfortunately, depending on who you get when you ring up, the awareness of issues like mine are not spread evenly throughout the support staff (some of heard of similar problems, many haven’t) and I always find myself having to explain the problem every time I ring up and we have to go through the same troubleshooting steps that I have repeated innumerable times before.
So currently:
We have tried every obvious trouble shooting thing you can reasonably think of:
Now I should at this point probably talk about what I have attached (wired and wirelessly) to the router:
So I have a more extensive wired set up than some but nothing too dramatic (IMHO).
Anyway I’ve doing as much trouble shooting as I can from this end and have come to the conclusion that the router can’t handle running this modest wired setup. I say this as because I have tested the router without any devices attached (using wifi only) and the router ran for over 24 hours without falling over. In a fit of excitement I then attached the router back to the wired network (by connecting into the nearest network switch in the room) and the router fell over about 2 hours later. So I then began the worlds slowest game of whack-a-mole and resorted to plugging in only 1 device (directly by moving the NAS next to the router) and it fell over in about 6 hours. So then I tried connecting 2 other devices in instead (the tv and the playbar) and it too fell over a few hours later. So far I haven't found one consistent device that, when connected, is the source of the resetting.
Yesterday things got even worse as the voice service would not come back on after it tripped and reset itself. I did both hard and soft resets but to no availabe - still no voice service. So again I rang up sky this mornging. The conversation did not, unfortunately, fill me with much hope. The guy seemed first to be convinced it must be an OpenReach issue and I had to spend 20 minutes demonstrating that it wasn’t. He then variously suggested that:
So we’ve left it that I will plug, directly into the router, a few devices and he’ll call back tomorrow afternoon to see if it has fallen over yet. Where we go from there, I’ve no idea.
To be honest I’m at my wits end on this - having had to reset the wifi on every wireless device in the house 4 times due to the router changes, having to reconfigure the survelliance package on the NAS everytime I do a reset due to the IP cameras being given new IP addresses etc - it's exhausting after a while.
I am seriously thinking of asking for the service to be cancelled and that I then move over to another provider – probably BT as at least then I can provide my own router if needed as I’m convinced that the current Sky router / firmware is the source of my troubles.
Any thoughts/comments appreciated.
28 Apr 2021 03:49 PM
Posted by a Superuser, not a Sky employee. Find out moreHere's something to try but may not sort out the problem.
Log on to the router and go the the Advanced --> WAN setup page and change the Router Mode option to "WANoE Only". By default it's usually set to "Auto".
I had something similar happening when my SR203 was connected to a separate modem and the Router Mode was set to the default "Auto" option.
28 Apr 2021 04:49 PM
Thanks @simon194 I'll give it a go.
07 May 2021 04:07 PM
Did this suggestion work @IanPJones ?
I have a problem where the connection to my PC keeps dropping - maybe three times a day. It's actually hardwired to a TPLink powerline soccket that has worked perfectly before. Our internet connection drops then re-connects 45 seconds or so later. Very annoying. Spoken to Sky multiple times, had replacement router and an engineer visit. Nothing changed although the engineer did say that our Ring cameras could be the cause. Were you told this?
We don't have a landline phone plugged in.
07 May 2021 04:21 PM
Is that on FTTP, G.fast or FTTC? There's a particular potential incompatibility between G.fast and Powerline hardware.
08 May 2021 01:58 AM
Hi @Hikiwari ,
Unfortunately it didn't help. I haven't had the advice about the Ring doorbell (though mine is on wifi not hardwired and wifi doesnt seem to cause me a problem). In the end I've given up and will be switching to BT to see if their router is any better.
11 May 2021 12:16 PM
Thank you @TimmyBGood I think I now need to talk to TPLink to see if they can help. I'm grateful for your help.
Thank you @IanPJones It may well be the way that I go too. I have more investigating to do.
Cheers.
11 May 2021 01:37 PM
Posted by a Superuser, not a Sky employee. Find out moreNot likely TP-Link can do anything. Due to the similar frquencies, Powerline adapters & G.Fast often just dont work together without casuing internet drops.
11 May 2021 02:28 PM
@jamesn123 Thanks but what actually is a Gfast?
11 May 2021 02:31 PM
Posted by a Superuser, not a Sky employee. Find out moreG.Fast is technology used to deliver your broadband service, however it depends on which package you have. Do you know what service or speed you are paying for?
11 May 2021 02:32 PM
G.fast is a 150 Mbps variant of ultrafast delivered through the copper telephone line as opposed to full fibre which is fibre to your premises
11 May 2021 02:38 PM
OK, thanks. So I have my computer in my front room and my router 45 meters away in my hall with a brick wall inbetween which means I only get 2 or sometimes three bars of WiFi. Not enough to have a seemless working day of internet use. Drives me nuts.
How else am I going to get internet connectivity?
A Sky engineer came around and blamed my Ring security cameras.
Dell say it's not their problem (although this never happened before my recent hard drive change)
Microsoft say nothing to do with them
MY ISP says not their issue.
WTH am I supposed to do??
Any suggestions gratefully received. Cheers
11 May 2021 02:39 PM
Posted by a Superuser, not a Sky employee. Find out more- Get WiFi boosters
- Move the hub closer
- Run an ethernet cable
- Buy a stronger router
11 May 2021 02:46 PM - last edited: 11 May 2021 03:01 PM
Certainly not the responsibility of Sky/Dell/Microsoft or any ISP: their remit does not extend to coping with the physical environment of anyone's dwelling place*.
You're looking at instigating the kind of solutions that @jamesn123 suggests or employing someone else to do so.
You can think of it in the same way as mains power and water: up to the point they arrive at your address that's the domain of a much larger business but inside your house you need an electrician, a plumber, or suitable DIY skills ; )
*apart from the very limited 'guarantee' of low-speed wireless coverage offered on premium broadband subscriptions by some ISPs, which actually only a guarantee there will be no additional monthly cost if coverage is not possible.
12 May 2021 08:08 AM
☹️ Thanks for your replies but none of this is very positive is it? Sounds like I'm stuffed.
