The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
20 Nov 2021 03:02 PM
2 years searching for a code to operate a bauhn TV.
I have tried all the codes for Phillips,Zephir,Akai,Hitachi,Vestel.
Would appreciate any advice.
21 Nov 2021 10:24 AM
Hi Marynix, what is the code for? Is this a code to pair the remote to the TV?
21 Nov 2021 11:53 AM
Yes to pair the sky remote to the TV
21 Nov 2021 11:58 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you've tried the codes listed by Sky's remote code finder to no avail, then no code has been previously found to work with your TV. You can check ALL the codes held by the remote to see if there's one that works but it's a laborious process. If you want to try it:
1. Press Select and Red together for several seconds until the LED flashes twice.
2. Press TV then standby alternately (TV, then Standby, TV, then Standby etc) until your TV switches off. If/when it switches off, press Select to store that code.
If you find a code that works, post again and someone will explain the 'blink back' procedure so that you can establish which code worked.
