1076
Discussion topic: Lip Sync issues - Sky Stream
Thread title created to reflect current issue
Moderator note: Amended title to better reflect query
This message was authored by Chloe-W22 This message was authored by: Chloe-W22 Answer
Posted by a Sky employee
Hi all,
We want to thank you again for your patience whilst we investigate the issue with Lip Sync on Sky Glass and Stream. We understand that this has been frustrating and we’re sorry for the inconvenience this has caused. We thank you for sharing examples of the issue, these always help our Support Teams working hard behind the scenes.
On Tuesday we began rolling out software version QS034.023.02 to Sky Stream customers, and this morning have begun the rollout for QS034.023.04 for Sky Glass customers to improve the lip sync experience.  The software update is a gradual rollout, where we expect all Sky Glass and Stream customers to have their new software by the end of January.
Thank you again for getting involved in this discussion and we will continue to monitor any feedback on this thread following the update.
I'll be marking this reply as the answer to the thread so more people see it.
Chloe-W22
Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by iretteri This message was authored by: iretteri
Sky Stream Lip Sync
Hiya. I've not had sky stream long and I am not liking it at all. I keep getting lip sync issues. I have done everything that is suggested. Go to settings -sound -digital audio delay. I've switched the puck off and on at the mains. Still an issue. Very annoying. I'm hating sky stream. Wish I still had sky Q. No issues with that. Are the lip sync issues going to be sorted does anyone know. ? Or is it something people will have to put up with. At this present time I don't rate this product at all. It appears I'm not the only one. Lots of people complaining about this issue.
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Sky stream lip sync
@iretteri
Seems to affect certain tvs
quick fix is to go into sound settings and change the sound to stereo
43inch and 55 inch Sky Glass & sky live camera 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims.
This message was authored by Padam_Padam This message was authored by: Padam_Padam
@iretteri
My puck is pretty random with lip sync too. Some days it's fine, others it's a few frames out on one app but fine in another. At other times it seems impossible to keep in sync on anything.
The best advice I can give is to make sure you have all picture processing turned off on your TV for the HDMI input the puck is attached to. If there is a game mode or low latency mode on your TV try selecting that. Doing this seemed to help a little for me, but TBH I just tend to use my TV apps or Firestick for a lot of stuff now - they don't struggle with maintaining lip sync, it's just the puck.
I've tried two different brands of TV too and it's the same on both. Not great.
This message was authored by IanWhite This message was authored by: IanWhite
Audio lip sync problems
The lip sync on my tv is all over the place! It is so bad that I'm having to watch Freeview to gain any enjoyment at all...this negates any need to have Sky tv. I'm resolved to cancel my subscription at the end of contract . The severity of the problem varies between channels so any form of adjustment is pointless. The problem also varies from day to day. Has anyone got any suggestions? Or do I have to continue to pay for an inferior service?
Lip sync problems with puck
The lip syncing on my service is atrocious, I have to watch Freeview to gain any pleasure from tv. This makes my subscription pointless. I will not be renewing!
The fault varies in severity from channels to channel and from day to day , so any adjustment is pointless and really shouldn't be required! With any other purchase we would be able to return and get refund as this is not of the quality expected.
Anyone else suffering like me with the puck.
for info, the tv is connected direct to puck with high speed good quality HDMI cable and internet service is by fibre cable direct to router @ 200 meg up and down! Wireless .
Re: Lip sync problems with puck
@IanWhite
Yes. Same for me. I posted about it on this thread the other day.
It's unfortunate, but if you're sensitive to lip sync (which I am) then using the Stream puck can be a pretty annoying experience. It seems to affect some people worse than others, depending on their TV and how it's set up. Many people just don't notice and live with it (probably because they're too busy looking at their phones at the same time as 'watching' TV.) 😁
Re: Audio lip sync problems
@IanWhite is this on a Glass TV or with a Stream Puck. If the latter how is the puck connected to whatever is producing sound. Glass normally doesn't suffer from lip sync where its own speakers are used but occasionally some channels can be poor.
This message was authored by Capt555 This message was authored by: Capt555
I had the same issue. I knew it wasn't my setup because everyday was the same. Would start OK then throughout the day would get worse and worse.
I had to fight for weeks to get sky to send a replacement puck.
New one was fine.
I wish I'd never changed to Stream. It's awful.
This message was authored by Rastrolex This message was authored by: Rastrolex
I get the same and we shouldn't have to dumb down quality settings to get what we paid for.
As soon as my contract is up I'll be cancelling.   Apart from a few Sky specific channels I can get what I need streaming or catchup on my Apple TV.
Good morning. The puck is connected direct to the tv via HDMI.
This message was authored by gszab1 This message was authored by: gszab1
Try to set the "Digital audio output HDMI" setting to passthrough.
Tried that. Doesn't make any difference.
I just happily use apps on other devices now (which have no trouble with sync) and only use the puck for the odd bit of live TV and Sky on demand.
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@Padam_Padam have you considered to Sky's budget service NOWTV ... Entertainment&HD £5.99 with discounts ... good saving on Sports😉
I already have it. Not interested in sports but I have Entertainment at £2.99pm and Boost at £3pm. Works much better than Stream on my Apple TV 4K box with no lip sync issues whatsoever. Stream will be leaving us soon - it's over-priced and under-powered. 😁
