2
Discussion topic: sky viewing card
This message was authored by corsa This message was authored by: corsa
sky viewing card
every time I turn on my sky box I have to re install my viewing card  this a replacement card only just received
This message was authored by oldfella This message was authored by: oldfella Answer
Re: sky viewing card
Hi @corsa
First check that your viewing card is correctly inserted.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @corsa
corsa
viewing card
thanks for rapid response regarding my viewing problem solved within minutes😊
