This discussion topic has been answered Discussion topic: Tv signal problem
Message posted on 29 Dec 2024 02:06 PM
Message posted on 19 Jan 2025 12:29 PM
No signal or no satellite signal?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Message posted on 29 Dec 2024 02:08 PM
Re: Tv signal problem
@Steve+quinnell wrote:
I'm just wondering if I can get a discount of my bill for the interruption it has caused.
It depends on what the issue is and Sky are unlikely to consider any credit prior to reporting it to them...
Is it a satellite reception issue do you know?
Message posted on 29 Dec 2024 02:14 PM
Yeah most probably as my channels are back now but it just happens out the blue. Thanks for helping
Message posted on 29 Dec 2024 02:28 PM
@Steve+quinnell wrote:Yeah most probably as my channels are back now but it just happens out the blue. Thanks for helping
If it's your own dish then it's likely to be a small alignment issue.
Message posted on 29 Dec 2024 03:40 PM
Flickering doesn't sound like a dish thing. That's usually binary - either working or "no sat signal".
Message posted on 19 Jan 2025 12:17 PM
Tv signal keeps dropping out
Message posted on 19 Jan 2025 12:44 PM
Re: Tv signal keeps dropping out
Thankyou Daniel for your help I need to book engineer
Message posted on 26 Jan 2025 01:59 PM
Tv signal
Message posted on 26 Jan 2025 02:05 PM - last edited: 26 Jan 2025 02:13 PM
You seem to have this issue frequently and ask each time on here and we provide the same advice. Have you called Sky to arrange an engineer?
Edit- your three threads have been merged and the post you marked as the answer last week is still relevant.
Message posted on 26 Jan 2025 02:09 PM
Re: Tv signal
Anyone having problems with sky Q tv signal in portsmouth area
Do you think this could be relevant?
Message posted on 26 Jan 2025 02:23 PM
Yes most definitely I bet sky love Britain due to weather because everyone is paying a lot of money and most of time you can't watch live tv due to weather. A massive thankyou for your help have a great day
Message posted on 26 Jan 2025 02:49 PM
Yes they have been out its just really bad weather in my area should be fine by tomorrow
Message posted on 26 Jan 2025 02:52 PM
But if your dish has moved, even slightly, you'll have problems again very soon.
Message posted on 26 Jan 2025 02:55 PM
I have a communal dish as I'm in flats
