Discussion topic: Sky q remote keeps saying low battery, even after replacing with new ones
Message posted on 02 Dec 2023 12:48 AM
As above... the remote stops working with the new batteries after a couple of minutes. Never had an issue with it before today, any suggestions????
thanks
Message posted on 02 Dec 2023 06:31 AM
Re: Sky q remote keeps saying low battery, even after replacing with new ones
You sure they were new?
Maybe the remote is faulty.
https://www.sky.com/help/articles/fix-q-remote-problems
until you get it replaced, you can use this;
Message posted on 02 Dec 2023 08:03 AM
Thanks. The batteries are new, I tried loads from a new box.
It must be the remote that's got a fault. I'll try to source a replacement
Message posted on 02 Dec 2023 08:49 AM
@D-D wrote:Thanks. The batteries are new, I tried loads from a new box.
Think the troubleshooter on sky.com ends with a way to request a replacement.
Message posted on 02 Dec 2023 09:30 AM
Yep I've oredered a replacement as the trouble shooting didn't work !!!
Message posted on 30 Jan 2025 01:07 PM
I am having this same problem despite having a new remote.
I did read somewhere that batteries from Amazon are not all they seem and as I bought mine from there just wondering?
