Discussion topic: No satellite signal
This message was authored by: DCT006
No satellite signal
When I open Sky it says.. no satellite signal.. to use this service you need a satellite signal.
No issues with Broadband or WiFi connections.
Whats the fix plz?
Re: No satellite signal
Sky Plus or Sky Q??????
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
@DCT006
Your answer to the above question will determine the advice you are given.
Avatar for DCT006
I've  Sky Q
@DCT006
I will move your post to the appropriate place.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
This message was authored by: Invisiblename
Whats the fix plz?
Sounds like your dish has been blown out alignment.  You'll either need to book an engineer with Sky, and the wait for that could be many weeks, or contact a local independent and accept the cost.
I am just another Sky customer!
