Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 15 Jul 2024 12:13 AM
							Re: Netflix: Red Spinning Circle on Launch
@Anonymous Frustratingly Netflix does not recognise my Sky ID/Email and just says no account found for this email address. Thanks for your advice though!
Message posted on 15 Jul 2024 07:44 AM
@sad+face wrote:@AnonymousFrustratingly Netflix does not recognise my Sky ID/Email and just says no account found for this email address. Thanks for your advice though!
Have you used different emails with Sky perhaps? I've got 3 I think, the Sky one, a Yahoo email and my Gmail one but for netflix our log in is the sons email as he had a netflix account before we switched to Q.
Try a password reset with ANY emails you have and see which works, you do have an online account due to your Sky sub for it.
Message posted on 15 Jul 2024 07:46 AM
							Re: Netflix won’t load
@Hammer1968 wrote:The same with me, it's really annoying that I can't get it to load. Sky are about as useful as a chocolate teapot as well
The fix is on page 1, 2nd post.
Message posted on 15 Jul 2024 10:06 AM
							Netflix doesn’t load
Netflix repeatedly never seems to be able to load when I try to access the app.
All other apps load fine, I have a brand new router so it's not router related issue.
Ive been through all the various procedures, turning off the Sky Q at the socket, reloading the Netflix app when I did manage to get it up and have downloaded Sky software update but still Netflix fails to load
Message posted on 15 Jul 2024 11:38 AM
							My Netflix isn't working, it just shows black background with Netflix and the red buffering circle
Message posted on 15 Jul 2024 12:00 PM
							Re: My Netflix isn't working, it just shows black background with Netflix and the red buffering circ
I have moved your post to this large topic where this issue is being discussed as it isn't related to Sky Go where you had posted. There is a possible fix here in the second post:
Message posted on 15 Jul 2024 12:02 PM
							Re: Netflix doesn’t load
Have you tried this:
Message posted on 15 Jul 2024 03:58 PM
							Netflix App not loading on Sky Q
Message posted on 15 Jul 2024 04:05 PM
							Re: Netflix App not loading on Sky Q
As your issue isn't related to mobile apps I have moved it to the large topic already discussing this as a possible fix has been posted, so see the link in the post that is above yours.
Message posted on 15 Jul 2024 07:03 PM
							Netflix not working
Message posted on 15 Jul 2024 07:29 PM
							Re: Netflix not working
I have moved your post to this large topic where this issue is being discussed in the Sky Q forum. There is a possible fix here in the second post:
Message posted on 15 Jul 2024 08:56 PM
This worked for me @Pg666 thank you 👍
Message posted on 15 Jul 2024 09:20 PM
That's great to hear. Enjoy
Message posted on 15 Jul 2024 09:24 PM
Hi, I've got main Sky Q box downstairs and two miniboxes upstairs, Netflix on one of the upstairs miniboxes is just giving me the red spinning circle, the other upstairs minibox works ok. Tried unplugging box, reset router, tried resetting apps, tried holding play/pause and back button for about 30secs. Is this likely a fault with the minibox?
Message posted on 15 Jul 2024 10:20 PM
Having the same problem netflix works fine on the small sky box in the other room but not the main skyQ box tv! Would love to inow what Sky are doing snout this
