31 Aug 2023 07:09 PM
I've not bothered calling them? I'm not sure what they can do as it's A software issue and the call centre people are not teccies!!!
I was told by a very aggressive mod on here that Sky do monitor this forum so lets hope the do
31 Aug 2023 07:15 PM - last edited: 31 Aug 2023 07:19 PM
@steve+bendell wrote:I have it back now after refreshing the apps in the hidden menue, but it takes time to take effect usually overnight.
Just out of interest has anyone got any help from Sky, I get fed up with waiting on the phone, Sky should be monitoring this and acting on it. They use this to stop us calling them, absolving their respposibility.
One of the Sky employees on here asked for some details from the box which she passed on to the techies, I have no idea if that was what helped but a while later and I've not had to reboot for a few weeks now.
31 Aug 2023 07:18 PM
Perhaps the employee could pass on all our concerns. Appears this is a very common problem. I've given up using the Sky app. Using the Amazon Fire Stick to access Netflix. No issues with Prime or Apple TV.
31 Aug 2023 07:27 PM
I'm having the same issues as everyone else. Netflix load screen just spins round and round. So annoying! Tried all the suggestions on here too and doesn't seem to do anything
01 Sep 2023 10:38 PM
I am getting so fed up with this now coz I have been having this problem continuously since I had fiber broadband put in July everyweek it happens & nothing seems to work. It's not netflix as I can watch it on my smart TV and on my phone but only problem is on the sky q box.
I have phoned sky so many times & thinking about making an official complain to have this sorted out.
01 Sep 2023 10:48 PM
If only Sky bothered to read these comments and act upon them.
02 Sep 2023 10:10 PM
I'm having this same issue, it just will not load. Yes I've done all of the past suggestions, so now what?
@QSky
09 Sep 2023 12:03 PM
I'm having the same problem with netflix loading on my sky q box as everyone else. Just rebooted but that made no difference, I'm in the middle of refreshing the apps, so far no difference, have tried the two button press thing, also no good. Come on Sky this is ridiculous get your finger out and fix this!
09 Sep 2023 03:16 PM
I'd love to know what, if anything, Sky did to mine then because it's still fine since I passed on some details from the App.
10 Sep 2023 04:20 PM
Okay, long post...
A probably somewhat reliable (but slow) solution
Open the Netflix App, wait 10-20 seconds to see if it loads. If not, close the app. Open any app other than Netflix. Close that app. Open Netflix again. Repeat maybe a dozen times, until it works.
What's the problem? (mostly guesswork here)
The Netflix app is really two systems: the "client" on your actual box communicating with Netflix's server. Since the problem seems to have appeared on all kinds of user-side machines without being tracable to a particular update, it is very likely that the change happened on Netflix's end. The problem also only appears while starting the app, so it's likely related to the login process. At least for me, the problem appeared around the time Netflix announced that they would crack down on multi-household accounts. It's possible that they are doing that by adding another step to the logon protocol, one that is only sometimes required. If that's the case and the Netflix app on your box does not support that step correctly yet, it will simply fail and continue to "load". But again, this is just a best guess.
Why do some solutions seem to work?
IF this explanation is correct, it's really just a matter of repeating the process until it works. But for that, the Netflix app needs to be completely closed after every attempt. By default, it seems to remain active in the background and thus you are not actually starting a new login attempt every time you open it. Solutions like software updates or system reboots will obviously shut the app down. It's much easier, though, to just briefly open another app because it seems that only one app can remain active in the background at a time.
What can we do long-term?
Not much, really. Netflix and Sky (or whoever is developing the app itself) need to sort this out and probably roll out a patch. For that, they need to actually be aware it is happening.
I hope this is helpful to anyone. No guarantees about anything.
10 Sep 2023 06:17 PM
Posted by a Superuser, not a Sky employee. Find out moreNetflix is a very complex web of
microservices, some of which are being upgraded / tested with different customers at different versions. However, the basics of opening the app should just work for everyone and it's not happening on all kinds of user devices is it? Just on Q (at least as far as this thread has revealed)
10 Sep 2023 06:31 PM
You would think Netflix would test out it's service with Sky wouldn't you?
Nah! Much to obvious to do that 😅😅😅😅
10 Sep 2023 06:38 PM
@MarkJ22 wrote:You would think Netflix would test out it's service with Sky wouldn't you?
I have just done it on their behalf and it worked. Showed list of profiles within 2 seconds. Happy to help 😉
10 Sep 2023 06:52 PM
Yes, many of us get the same from time to time but sadly it's not all the time and if you've just settled in to watch something and it won't load it's very frustrating.
Maybe, as you're a SUPERUSER you could bring your influence to bear in Sky to get this issue sorted out for the majority of us who have posted here and the many others out there with the same issue?
10 Sep 2023 06:57 PM - last edited: 10 Sep 2023 06:58 PM
@MarkJ22 wrote:Yes, many of us get the same from time to time but sadly it's not all the time and if you've just settled in to watch something and it won't load it's very frustrating.
The idea that I have any influence whatsoever is heartwarming 🙂 I have no doubt it's linked to the Q's wild and unique networking code. I gave up on wifi and can only recommend everyone else does the same.
fwiw Netflix always works for me (luckily as the 2 TVs with minis are not Smart enough to have Netflix) but iPlayer almost never works.
Search Sky Community
