- Mark as Read
- Report comment
FP1997
Got a new Sky Broadband Hub, but don't want the hassle of a new name and password?
Check you're connected to your Sky Broadband, then:
- In a browser address bar, go to 192.168.0.1
- Select Wireless or WiFi.
- Enter the default username admin
- And depending on which hub you have, the password sky or the WiFi password on the back of your hub.
- If these don’t work, follow the Resetting your WiFi password steps below then try again.
- Enter your 'Network Key' – that’s the WiFi password you want to use. Here, you can use the password from your old Sky Hub!
- Select Apply to save your new password.
Your devices will automatically log back into the wifi. Don’t forget about smart home devices like thermostats and any Sky boxes.
Wi-Fi QR Codes
There are 3rd party websites where you can create a WIFI QR code. You can then print it off and stick to your Hub and house visitors can simply scan the picture and boom! Logged in!
Without the hassle of entering the complex codes, the free site I’ve used for my home QR is https://www.qr-code-generator.com/solutions/wifi-qr-code/.
Labels:
Leave a comment
